Is 68 GB enough free disk space to run Civil 3D well?
ChrisRS
Mentor Mentor
ChrisRS
Civil 3D is already installed.
Is 78 GMB enough free disk space to run Civil 3D 2022.
Christopher Stevens
rl_jackson
Personally, I would think you're ok, this does depend on the amount of ram you have on the system and the page file size. It also will depend on drive type and just how full the drive is, i.e. is 68GB what remains of 250GB. I try to do a 50% rule on my SSD's as they seem to run better, so a 1TB drive is technically full at 500GB and then will start slowing down. Also there are affects by the Windows Page File size setting, that is generally based on RAM some info regarding this can be found here:
How to determine the appropriate page file size for 64-bit versions of Windows - Windows Client Mana...
Swap file in Windows 10: optimal size, how to change, move, disable or delete it? (recoverhdd.com)
There are other things that can affect speed but I think you'll be fine.
Rick Jackson
Survey CAD Technician VI
