Intersection design
Intersection design
Intersection design
Is it possible to edit curb return profiles, generated automatically from Intersection method of design for simple T-junction?(Civil 3D 2015)
SMorykin
@Anonymous - I believe it is possible, what specifically do you want to edit?
If this post solves your issue or answers your question, Please select the ‘Accept as Solution’ button so other Community members may benefit. Thank you!
Jeew-m
Dear Friend,
Yes you can.
Click here to see the methods.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Hi!
Thanks for your quick response.
I want to edit profile or add new profile for the curb return alignment.
Intersection wizard automatically generates profile for curb returns, I need to edit that profile to suit the requirements. How can we change that profile?
Jeew-m
I think you have a trouble because you cant see a profile.
Create a profile view to curb return alignment.
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Civi...
Then you can edit the profile.
https://www.youtube.com/watch?v=XFaAofLrxpU
Jeewana Meegahage
Design Engineer
Hi!
I wanted to know how to introduce a curve to that profile, as I see from the profile we cannot do any modifications.
We will be having only tangents between alignment, that produces sharp kink in the intersection. I want to smoothen that out.
