When I choose a txt file with a lot of points that I want to insert into my drawing, it only selects the first 20 points. How can U change this so that all the points in the txt file will be inserted.
Also, how do I insert a point group into a drawing?.
Is the format txt ?
this video could help you, takes 10 minutes but is worth the time so you can get the hang of it.
https://www.youtube.com/watch?v=WyCG5YYm83A
thank you
Welcome to the forums, @Anonymous!
For the first question, your PointFileFormat likely has the option shown below checked with 20 as the number.
You can copy point group (definitions, not points) by drag-n-drop in Prospector between open drawings.
