Civil 3D Forum
inserting dwg files into other dwg files
4 REPLIES 4
2232 Views, 4 Replies
With earlier versions of Civil 3D I was able to insert dwg files into other open dwg files and all the layers/settings would come along with the inserted file but Civil 3D 2020 seems to treat the inserted file as a totally separate drawing???
4 REPLIES 4
MMcCall402
Walk us through the process you use for inserting the other drawing.
Is it inserting as a block or Xref?
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
in reply to: MMcCall402
I think I tried both block and xref, the xref is definitely giving me trouble as it is not bringing in layers and settings to combine with the current drawing. I picked insert, then attachment and it is bringing it in as an xref; should I insert it as a block?
ToddRogers-WPM
Have you tried using the import styles and settings?
Todd Rogers
MMcCall402
Attachment will create an Xref.
Run Insert command, choose the drawing file you want to insert and check the box for Explode. This will insert the other drawing into your current drawing, with all its layers and settings, but not as a block.
Another option would be to right click on the file in and open file manager window and drag it into the current drawing in model space. You be given the options for an Xref or Insert.
An Xref can be turned into an insertion by selecting it and choosing Bind and then Insert from a right click menu. This will insert it as a block that you can then explode.
Mark Mccall
CAD Mangler
Linkedin
Rail Community
