Insert object data table into drawing
mikeFNR3E
mikeFNR3E
Community Visitor
Community Visitor
In Civil 3d I have a set of polylines that have object data attached to them using an object data table. Is there a way that I can insert / show the object data database table for all of these polylines on one of my layouts? Also, can the table be linked to the source database so that changes to the object data on the polylines is updated on the table on my layout?
lim.wendy
Hi Mike,
Thank you for submitting your question in our discussion forums.
I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community!
@ChicagoLooper  and @Pointdump, we would appreciate it if you could offer valuable insights and guidance into OP's question.
Meanwhile, take a look at the following resources to get some ideas:
Map Newbie - Help with Object Data
To Create an Object Data Table
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
chriscowgill7373
where is the object data coming from?  I dont have much experience with it, but usually when I hear object data, I think shape file.  I dont know if there is a method you can use with ADEQUERY to bring in a table type entity.  Usually data pieces have a specific insertion for that data when you perform the query.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
