Insert 3d model to Civil3D 2022
off.wni
off.wni
Dear All,
I try to test to insert 3d model into Civil3d as attached.  1.PNGThis test is trial to develop to insert of bridge pier in 3D model. After that, I project these into profile view to generate elevation view by using "Profile View>Project Objects to Profile View". The model shown in profile view as attached. 2.PNG
The model are projected to profile view by refer to CG at profile line which is not correct. Prefer is require to project at top or other points to be used as reference to profile line.  Please be asked that how can I project the model to correct elevation??
Thanks in advance.
WNI
Beka_Tchigladze
You can change your elevation reference by this row just click it and choose reference object to attach vertically, I think you have to assign to use object elevation no?
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
off.wni
I had trial on that feature. The elevation options on this box is for used in identified on Civil3D objects such as profile view, custom elevation, surface or profile(I identified herein is profile). However, the reference point on 3-d solid object still at centroid of model.
Beka_Tchigladze
@off.wni
If you will drop down, You see lots of options in the list. you have to assign use object if your models are at the right elevations, if not, you have to put it at right elevation, otherwise you have to let the objects to follow some reference.
I tried and it works like a charm.
Beka Tchigladze
