Inlay Design -New Road Crown
kevin.moranVRCAR
kevin.moranVRCAR
Hi
I wish to create a new road crown. please see snip below. the road crown has deteriorate and the contours spike down to a lower level after the solid white lines. how to i project a new accurate road crown to complete my inlay design
matt_anderson_pe
Well - the bent contour shows a TIN face edge isnt as it should be.
Two items - turn TIN faces on for your corridor surface.  Review the breaklines contents of the corridor.  I assume the solid white lines aren't part of the surface.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
