@dana.probert wrote:
If you then add specific corridor feature lines to the corridor surface, that can also help lock down any errant bits and pieces.
Blast from the past ... Thanks for this suggestion, Dana! I had a corridor where all the links looked correct, but the surface triangulation just would NOT work right. One point was always skipped, leading to an improper slope. All the codes checked out ... I was at wit's end. But this suggestion, to extract the corridor feature line and add it to the surface, has fixed it! In modern versions of Civil 3D, the feature line can even stay dynamically linked to the corridor. Finally, I got my surfaces fixed and I can move on!
