Civil 3D Forum
incorrect displaying a file in Civile 3D 2023
4 REPLIES 4
rekos.paulina
252 Views, 4 Replies
Hi, I attached image with two screenshots on it. Both show the same file in two Civil 3D 2023 insatled on two computers with the same parameters.
Image 2nd is displayed correct. Has anybody idea why 1st displays incorrect? lines are 'dots', there is no hatch visible on corridor, sample lines are 'invisible'...
What I've done till now:
1) Civil was reinstalled
2) I have updated my graphics card driver
3) I have checked if it's a matter of line styles or scala settings and it's no
Labels (1)
4 REPLIES 4
user181
in reply to: rekos.paulina
Even if you updated your graphics driver you may still need to adjust some settings with the GRAPHICSCONFIG command. Have you tried changing the 2D Display setting from advanced to Intermediate or Basic?
nkiakas
Hi @rekos.paulina
Could you please share you file with us?
Highly recommend turning of 'smooth line display' or turn off hardware acceleration.  You can turn off smooth line display by typing in 3dconfig, press the details button, and uncheck smooth line display.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Thank you for your help. In this case it turned out that choosing Basic Mode in Graphic Performance solved my problem.
Rail Community
