Civil 3D Forum
Incoming and Outgoing pipes leader arrow pointer
3 REPLIES 3
Sinoj.Ravindran
301 Views, 3 Replies
Hi..
While labelling structure incoming and outgoing pipes in  a profile view, dragged state pf that label always pointing towards the structure but not to the exact respecting pipes inside structures.
Any solution..?
3 REPLIES 3
wfberry
in reply to: Sinoj.Ravindran
Not with labeling the structure but I think you can change the pipe labeling to show at the structure.  Perhaps use Google to locate this procedure.
Bill
Hi @Sinoj.Ravindran
Try using your style for inflow pipe to have a drag state at the top or bottom of the structure or using a new defined style that leverages line components to position a predefined drag state anywhere on the structure.
Grzegorz Cwiek
Hi Grzegorz,
I have done it that way..
But the issues for  my style is that all the pipes incoming to the structure labels will show up.
Actually I need only other than the main pipe of that profile to show up.
This is not possible with label style composer as the 'text for each' - @Anonymous in flow pipes' option gives all inflowing pipes to the structure to label.
Regards
Rail Community
