Thanks for providing the additional information. It sounds like you have a handle on your RTk-GPS Survey equipment tolerance. You’re correct that your RTK-GPS is referencing a correction source that is most likely using the latest WGS84 Datum. It is hard to pin point which realization of WGS 84 Civil 3D uses, so I would try to format your .shp data to UTM Northing Easting coordinates prior to bringing into Civil 3D to take Civil 3D out of the equation when applying the UTM mapping projection (if Civil 3D has an older version of WGS 84).
Also with regard to your overall Site size and the 8500 foot distance measurement check you mentioned. Distances measured in Civil 3D will be “GRID” distances not “GROUND” distances. Google Earth distance inquiries are “ellipsoidal” distances (which factor in the curve of the WGS84 ellipsoid)...these aren’t technically ground distances either. Knowing how to work with Grid, Ground, and Ellipsoidal distances is part of the Professional Surveying craft and depends on lots of factors (e.g., where you’re at relative to the mapping projection Standard Parallels, how much elevation relief you have, etc). So my point is that the 4ft error you’re seeing Civil 3D over that almost 1.6 mile distance is most likely due to the difference between Grid (Civil 3D) and Ellipsoidal (Google Earth) distances. Apples and oranges with respect to measurements.
In summary it sounds like you’re doing mapping level stuff with solid GPS equipment, so don’t sweat if you’re measurements aren’t exact in Civil 3D. You will always have the raw WGS84 data to fall back on. When you go to Engineering Design and then construction, you will need to worry about this tightening the accuracy further.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
