I recieved a dgn file from the Army Corps of Engineers. I imported it into an acad file. When I did, everything seems to have moved into outer space.
I discussed this with my contact at the Corps and he confirmed that his file is set up to be in the same coordinate zone that I'm using (MO83-EF). So I had him place three cogo points in the file and give me the coordinates of those points. After I imported his file again, I checked the coordinates of those points against what he said the coordinates SHOULD be. They're still out in outerspace.
So I moved, rotated and scaled EVERYTHING so that the coordinates now line up perfectly. Having done that, I can reference his file into mine without issue.
What about the import process could cause this?
When importing, I saw an option to convert sub-units or master-units to dwg units. I tried both options and saw NOTHING different between the two imports. But that was the only thing I could find that seemed like it MIGHT make a difference.
Can anyone offer any ideas as to what's causing this?
He's using Microstation V8i Select Series 2.
Don Ireland
Engineering Design Technician
Solved by ToddRogers-WPM. Go to Solution.
So it was the right units but in the wrong place? Not 10 or 12 times larger than expected? That's the kind of error I've seen and why they now give the Master or sub-unit conversion option.
Is it possible that there was the equivalent of a UCS in the DGN?
Allen
Allen Jessup
CAD Manager - Designer
I'm going to try it again and see how much I have to scale it to get it into the right place. But I tried changing the following setting Monday and regardless of which option I chose, there was no change (as best I could tell).
Don Ireland
Well I just reimported the file and then attached as an XRef my previous file (the one that's in the correct location) to this one. I changed the insertion scale to 12. Having done that I'm able to move the XRef right into place and all three cogo points line up.
So that at least seems to confirm there's an issue with the units. But I'm still at a loss as to what to do about it the next time I need to import a dgn file. I'm up a creek without a paddle if that happens and I can't get the sender (or someone else) to provide me with enough info to fix it.
Don Ireland
This might also lend a clue.
Allen Jessup
@AllenJessup wrote:
You should definitely be selecting Master units. Also see HERE.
Allen
That was my first inclination. But when I wasn't getting good results, I decided to try sub-units.
Don Ireland
