Import XML comes in at wrong coords and scaled
claytonh
Message 1 of 12
claytonh
I'm importing a LandXML file of an alignment and it comes in at the wrong coordinates and scaled. It's off by about 6 feet.
The LandXML file came from 2023 Civil3D from the city with a file setup on NM83-WF. I'm using 2022.
The XML file itself shows the 0+00 should be at X=2624088.957 Y=2094698.662 with a length=4187.5506
After I import it, 0+00 X = 2624083.7089 Y = 2094694.4727 with a length 4187.542
I'm guessing there is some sort of scaling happening, but I can't find where or why it's happening.
The XML file is attached if anyone can help I would appreciate it.
Clayton Harrison, PE
CHC Engineers, LLC
C3D 2024
Replies (11)
Message 2 of 12
Kyle-L
I believe it is a unit conversion error.
If I set the drawing units to feet and the conversion to "International Foot" then the alignment coordinates are exactly the same as the LandXml, but if I set the conversion to "US Survey Foot" then I see the problem you are having.
I don't know much about feet as I work in metres but try changing the conversion options and see if it helps:
Message 3 of 12
Pointdump
Hi Clayton,
Maybe a conflict with units? I don't know how you would change the "linearUnit".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 4 of 12
Pointdump
Clayton,
I changed linearUnit to "Foot_US" with Notepad++ and now it imports OK. Attached.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 12
ChicagoLooper
Hi @claytonh
Here are two options.
Option 1:
On command line type in  MAPCSASSIGN=>in search box search 2259=>select the result=>click assign
Insert your XML.
Option 2:
Insert your XML without assigning a coordinate system. After it's inserted, assign NM83-WF.
Chicagolooper
Message 6 of 12
claytonh
It still comes in at the wrong coords. I actually tried this previously. Thanks for the response, but something else is awry.
CHC Engineers, LLC
C3D 2024
Message 7 of 12
claytonh
Although this does work. Why?
I finally received the original drawing that this came from and it's setup on NM83-WF.
I deleted the alignment in that drawing and then imported the new one. It comes in just fine.
I started a new drawing with the _Autodesk Civil 3D (Imperial) NCS.dwt and it comes in fine.
This is telling me that there is something in my DWT that is messing things up. But what?
What is it?
CHC Engineers, LLC
C3D 2024
Message 8 of 12
Neilw_05
There is a setting in the LandXML export settings that can override the units used in your drawing. If users are not aware of this setting, the consequence can be catastrophic.
When importing an XML file into a drawing that has a coordinate system and units assigned, C3D will automatically transform the imported data to match the drawing. If the units in the XML file are different than the drawing, you would see a shift in the imported data.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 9 of 12
claytonh
Very dangerous indeed. When I change this setting to Survey Feet, export the XML and insert it into a new drawing, it works. The XML file created has the linearUnit="USSurveyFoot" instead of the original file of linearUnit="foot"
@Pointdump had the right idea and the only way to fix an XML that is sent to you.
Interestingly enough, I also get this error exporting the XML. This error ONLY occurs if you have a coordinate system applied.
Type: Warning
Date: 2/2/2023
Time: 10:27:36 AM
Source: Export LandXML
User: clayt
Description: The Drawing 'Imperial to Metric Conversion' setting specified in the Drawing Settings does not match the LandXML 'Imperial Units' setting specified in the LandXML Export Data Settings. Reimporting the exported LandXML file will result in different drawing.
This is such a strange error. Mainly because it's not true.
Thanks for all the help!
CHC Engineers, LLC
C3D 2024
Message 10 of 12
Neilw_05
Apparently they have added a warning since we first encountered this. The way we discovered the setting was after the sewer and water lines were already constructed in the wrong location on a project. We were not aware of the setting and there was NO WARNING from the software about the mis-match at that time. I notified Autodesk about it and they quickly took note.
Will have to test it out.
WIN 10 64 PRO
Message 11 of 12
claytonh
Again this really sucks and Autodesk did a huge disservice with the whole US Survey Foot and International Foot thing. I haven't found any reason for these settings other than conversions. Coordinates are coordinates, and unless you know that you need to scale, Civil3D SHOULD NEVER do this for you without your knowing. INSUNITS is another horrible disservice that can scale inserted files - again without your knowledge.
But note that the error only pops up when you have a coordinate system set. But the error is not true as the XML comes in correctly. Figure that one out.
I have a project that was just built with a water line and sewer line XML that I provided. Now I need to go find out if it was built in the wrong spot. SMH
Thanks again for all the help.
CHC Engineers, LLC
C3D 2024
Message 12 of 12
SoaresASBCAD
Just change linearUnit to "Foot_US" with Notepad++ and now it imports OK. Attached.Davev
ASoares
