Import specific LiDAR Classification code from .xyz file into Civil 3D?
Daniel_Hinks
Message 1 of 25
Daniel_Hinks
I currently have a large .xyz file i need to import into Civil 3D, however i actually only need the points with the code '20' listed next to the X,Y,Z columns (see imaged attached). There are many other types of points in the file with other codes up to 151 but as i say i only need the code 20... but i cannot bring the whole file in because it is too large.
If i can't do this via civil 3D... is there a alternate method i could use to filter out those points before hand perhaps? (I cannot use Recap).
Thanks.
Replies (24)
Message 21 of 25
Kyle-L
If you did not come right and are in a bind I wrote a small python script to extract all points of a single code (e.g. code 20) and put them in a new file. If you have python installed you can run the file from the command line. Extract the attached zip and run the file with python like this:
py extract20.py "input file path" "output file path" code
For example " py extract20.py sample.txt sample20.txt 20" will extract all code 20s from sample.txt and put them in sample20.txt
Note, use quotations around the paths if your paths have spaces in them.
Use at your own risk. There is minimal error checking and I did not test it on a large file like the 2GB file, but it reads and writes straight from and to the files, so hopefully there should not be any "insufficient memory" errors.
I do suggest that you try to use one of the approaches mentioned by other people though, such as QGIS, LASZIP or Cloud Compare. That will give you flexibility in future to handle different file formats/contents.
Message 22 of 25
Pointdump
Kyle,
Is Python a standalone DOS Program?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 23 of 25
Kyle-L
No. Python is a programming language. The file I provided is a script that python runs.
You can download python here:
https://www.python.org/
Message 24 of 25
Pointdump
Thanks Kyle,
I'm watching some vids on how to use Python in QGIS.
Dave
Dave Stoll
Las Vegas, Nevada
Message 25 of 25
jae.kwon
Sorry for the late reply, been a bit overloaded lately.
I use lastools to filter quite a bit, usually from laz to xyz but considering you're starting from ascii, you might want to use txt2las.
Try something like this:
txt2las -cpu64 -i "input.txt" -parse xyzc -keep_classification 20 -o "output.las"
If you want it back in ascii format you can just run las2txt on the output. (I'm not sure how to go txt to txt with lastools - maybe someone can tell us)
las2txt -i "output.las" -o "output_c20.txt" -parse xyz
