Import SHP File into Civil 3D
DaveMartin4189
Message 1 of 8
DaveMartin4189
I need to bring a SHP file into an AutoCAD drawing. I've always used the MAPIMPORT command to do this.  Now, in AutoCAD 2016, SHP files are not listed among file types I can import.
Is there a way I can do this?
Or, is there another way to import SHP files into an AutoCAD drawing file.
Thanks in advance,
Dave
[email protected]
Replies (7)
Message 2 of 8
wfberry
You have a conflict between your Message Title and your post text.
Autocad or Civil 3D.  No can do for AutoCad, but yes for Civil 3D.
Bill
Message 3 of 8
BushW
Hello @DaveMartin4189
If your using Civil 3D you can also use the mapwaspaceThis command will open the AutoCAD Map 3D Task Pane, which will allow you to create, manage, display, and publish GIS data using Map 3D.
At the Command line type=> mapwspace
Data Connection by Provider => connect to data
I hope this helps!
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 4 of 8
BushW
I just wanted to follow up here, any thoughts on my previous post? Are you still in need of help this problem? Thanks for the update!
Best Regards,
Wendell
Wendell Bush
Message 5 of 8
gonecrawfishin
Along these same lines, I have Civil3D 2018 and just recently (same software) I stopped being able to view my imported shapefiles' fields (using MAPIMPORT), even when I chose to "create object data". If I click on the imported object, none of hte fields are visible in the properties pane. Anyone else having this problem?
That data connection is a new concept to explore, but seems far more complicated than necessary.
Message 6 of 8
Pointdump
Jennifer,
Please post your drawing and a shapefile for testing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 7 of 8
mikeshick
How do you isolate the shp file to the area you need, to limit amount of data you bring in to drawing?
Mike Shick
www.medesigns.us
Message 8 of 8
Pointdump
Mike,
2 ways. You can "Define Window" at Import, or afterwards you can use MAPTRIM.
Dave
Dave Stoll
Las Vegas, Nevada
