Show only
Search instead for
how is it possible to import OKSTRA (.CET) with DACH-Extension. I tried with DACH-Extension but it did not work. The failure seems to be to the .CET-file. .XML should be able.
I recommend using the OKSTRA toolbox that comes with the DACH country kit. Unfortunately, it supports only OKSTRA XML files. However, .CTE file can be converted into OKSTRA XML file with OKSTRA-Werkzeug software.
