I want to import .XYZ file and I suspect that because there are a lot of points(more than 100,000) cause could not to import. I tried to just copy several points from the file and they showed probably. Is there a way to import a lot of points?
Solved by neilyj666. Go to Solution.
I'm not aware of any point number restrictions - at least for that number of points. Can you share the file so someone can try to reproduce the issue?
If you are just needing to create a surface (and unless there is a specific need to import the points) just create the surface directly using the points file which speeds up things considerably
neilyj (No connection with Autodesk other than using the products in the real world)
Refer to this post for solution - essentially what I said....!!!
https://forums.autodesk.com/t5/civil-3d-forum/unable-to-import-lots-of-points/td-p/12183151
