Import GIS then export to Autocad
I have just had a coworker import some GIS data in shp format. Then had him exporttoacad so that I can use the file in Vanilla autocad. When I open the file, there is nothing there. How can I get this data into Vanilla autocad?
Todd_Rogers
If you import (MAPIMPORT) a .shp file, it is already linework.  You should not have to export it back out to AutoCAD.  If you do a FDO connection with a .shp file, you can click the Maps button and select Save as AutoCAD Drawing.
Todd Rogers
Civil Administration
That worked like a charm...
I had made the FDO. Then tried an export to acad.
