- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Civil 3D 2014.
I have a file that was created from an Imperial template but the file since has been converted to a meteric file. The coordinates and units are set to a metric setting. I am taking length and areas of Autocad shapes by using the Properties dialog and cutting/pasting values into spreadsheet. After realizing that all my Ambient Settings are still in imperial; after toggling these settings to metric ones, I noticed that my length and area properties values did not change, luckily. The properties dialog does not show units, unfortunately, so I have assumed that the units are correct. I just wanted to confirm that using the properties of AutoCAD shapes such as polylines and closed polyline shapes will give me the appropriate meters length and square meters area from a file that was converted to metric from imperial?
