Civil 3D Forum
Image selection inside of a Lisp file is not working
2 REPLIES 2
karl.gouldingUGC2M
224 Views, 2 Replies
I have the following code which had worked on C3D 2020 fine but now that we have upgraded to C3D 2022 it seems not to work at all, if I break it up and run it individually piece by piece it works, but as a lisp routine it just doesnt.
(vl-load-com is loaded elsewhere)
Any ideas would be of help
(defun C:ifade (/ mycurtab imgss n featobj imgssobj)
	(if (not (= (setq mycurtab (getvar "ctab")) "Model"))
		(setvar "Tilemode" 1)
	(command "regen")
	(setq imgss (ssget "x" (list '(0 . "*image"))))
	(if imgss
			(repeat (setq n (sslength imgss)); then
			(princ (strcat "Images processing: " (itoa n) \n))
			(setq featobj (vlax-ename->vla-object (ssname imgss (setq n (1- n)))))
			(setq imgssobj (vlax-vla-object->ename featobj))
			(command "._imageadjust" imgssobj "" "F" "50")
			(princ (strcat "\n" imgssobj " set fade to 50%\n"))
		); repeat [then]
		(princ "\nSelection set for image not found\n")
	(command "regen")
	(if (not (= mycurtab "Model"))
		(setvar "ctab" mycurtab)
PSI have resorted to running this as a copy past into the command prompt.
(setq imgss (ssget "x" '((0 . "*IMAGE"))))
(princ (strcat "\nImages processing: " (itoa n) "\n"))
2 REPLIES 2
Is there a reason that you have this line commented out?
;(setq imgss (ssget "x" (list '(0 . "*image"))))
Yep I was testing different variations of the same thing and when I posted this I removed the other 2 but not the comment. Fixed it now
Rail Community
