IFC Export for Navisworks
philipp_hueberD4NDY
philipp_hueberD4NDY
Hallo zusammen
Wie kann aus Civil 3d eine IFC exportieren werden, die zur Koordination im Navsiworks verwendet werden kann.
Die erstellte IFC sieht im Navisworks wie nachfolgend dargestellt fehlerhaft aus. Ein weiter Screenshot zeigt die selbe IFC mit einem anderen Programm. Die Übergabe an den Kunden ist mit IFC Dateien vorgesehen und nicht mit DWGs.
Hello everyone
How can an IFC be exported from Civil 3d that can be used for coordination in Navisworks.
The IFC created looks faulty in Navisworks as shown below. Another screenshot shows the same IFC with a different program. The transfer to the customer is intended with IFC files and not with DWGs.
So sollte es aussehen
lim.wendy
Hi Philip,
Thank you for submitting your question in our discussion forums. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community! For your issue with exporting an IFC from Civil 3D to use in Navisworks, I recommend trying the troubleshooting steps discussed in this thread: IFC Export Corridor Problems. It addresses a similar issue and might have a solution for you.
Let us know how it goes.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
cwr001
Two things you can do:
Go to settings --> Dateireader --> IFC and set "Conversion method" to "Older Version (v1)". That's the not so clean way as this conversion method is obsolete.
The other way is to follow these steps. It's a bit of extra work but it gets the job done, usually.
I don't know why Autodesk isn't able to implement this properly (as opposed to most other companys that sell IFC-viewers) but that's the reality we have to deal with. 🙂
