In section views is this possible to add dimensions shown below (section view styles or labels)
Solved by Jay_B. Go to Solution.
Solved by sboon. Go to Solution.
It took some messing around but I was able to create something that might work.
I added two MarkedPoint and two LinkToMarkedPoint subs to the assembly. The LinkToMarkedPoint subs have a code "Label" attached to them so that the code set can apply a label between the points I want.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
