i have a buch of points. i just want a crude [grid] surface using these points
Message 1 of 8
hi.
is there a way to do that?  just a simple [grid] surface.. from some cogo points.  no point cloud... just the points
1 or 2 points per 1120 square feet (around 700 points)
Replies (7)
Message 2 of 8
Pointdump
Michael,
Welcome to the Autodesk Forums.
"Just a simple [grid] surface.. from some cogo points."
Not a Grid Surface, but you can use those points to make a TIN Surface.
Can you post your point file?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 8
tcorey
After creating the TIN surface, use SURFACEEXPORTTODEM command to export to a grid surface, and then use _AECCCREATESURFACEGRIDFROMDEM to create a drawing-base grid surface from the exported grid surface.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 4 of 8
TerryDotson
Exporting to .DEM rounds elevations off to the nearest whole meter.   Can't say what Civil3D does exporting .ASC or .TIF formats.
Message 5 of 8
Joe-Bouza
I dont know much about grid surfaces other than it sounds like the intention is to normalize huge data. wyh is a TIN unsuitable? for 700 point?
Joe Bouza
Message 6 of 8
Joe-Bouza
Well I see "Grid Surface" creation is so esoteric that there isn't a single youtube video on how to do it... WOW!
anyhow reading your post more closely I see "crude"
1. make you standard TIN surface
2. place cogo points by grid (to your liking) on the surface
3. make your " Crude Grid" TIN surface from those points
Joe Bouza
Message 7 of 8
tcorey
Sounds like a detail I should have known about. Thanks, Terry.
Tim Corey
Redding, CA
Message 8 of 8
tcorey
@Anonymous, thanks to @TerryDotson, I have realized that exporting to .DEM format makes all elevations round to the meter. If you export to GeoTIFF, that won't happen.
You will still use the same command as before, but just be sure to set your Files of type to GEOTIFF (*.tif). Files of type setting will be found on the dialog when you specify Dem file name from the Export Surface to DEM dialog.
Thanks, again, Terry, for straightening me out.
Tim Corey
Redding, CA
