I can't select or find my viewport
saif_dz_ob
Message 1 of 16
saif_dz_ob
I modified my layout to be ISO A1 (841 x 549 MM) DWG to PDF .pc3 and when I try to expand my view port it doesn't . please see the attached picture
Replies (15)
Message 2 of 16
Pointdump
Saif,
Switch to Paperspace and then you can Scale your Viewport to fit your Paper.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 16
saif_dz_ob
I've switched to Paperspace and yet can't expand the viewport .
Message 4 of 16
Jeff_M
How are you trying to resize the viewport?
Message 5 of 16
saif_dz_ob
Im trying to resize it to fit my paper . but I'm finding a problem in selecting the viewport like in the images .
Message 6 of 16
Jay_B
Does it work when a brand new Layout and Viewport are created?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 16
Jeff_M
Your images show that the viewport is resizing. You will need to change the scale that it displays in order to get the model to fill the new size.
Message 8 of 16
saif_dz_ob
No it deosnt change. The images that i uploaded aren't mine but im trying to do like in the images.
Message 9 of 16
Pointdump
Saif,
Need a little more information on exactly what you're trying to do and where things are gumming up. Please post your drawing and elaborate a little on the problem.
To venture another guess at what might be the problem, if you can't select your Viewport to grip-edit it, then maybe you have "New VP Freeze" frozen for your Viewport Layer:
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 16
saif_dz_ob
Please see the attached images
Message 11 of 16
Jeff_M
This is not likely a MapViewport. Go to your Layers palette, find the layer that the Viewport is on (hint, look for a layer that is froze, off, or frozen in the current viewport) and thaw it or turn it on.
Message 12 of 16
Pointdump
Saif,
Please post your drawing. We're running out of things to guess about.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 16
Joe-Bouza
Is it possible the viewport is on defpoints and layer zero is frozen?
Joe Bouza
Message 14 of 16
saif_dz_ob
Thank you a lot sir, I found some layers that were frozen . much respect
Message 15 of 16
saif_dz_ob
That is exactly what it was. the layer zero were turned off . Thanks ^_^
Message 16 of 16
saif_dz_ob
Thank you Dave for helping . I found out that the layer zero was turned off .
