Hydraflow HGL Issue with Box Culverts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have encountered an odd behavior with Hydraflow when attempting to run analysis on a box culvert running under pressure. Whenever I run the analysis, the HGL will not go above the top/crown of the box, even though the capacity of the box is clearly being exceeded. Hydraflow verifies this as you can see in the screenshot - The actual flow is 698 cfs, but the capacity is 390 cfs. However, the HGL just tracks along the crown of the box.
If I reduce the flow into the system to reach partial flow, the HGL line works fine since it's below the crown, but once the capacity of the box is reached, the HGL won't keep going up. Also, if I change the box to a circular pipe within Hydraflow, the HGL will jump up to the expected location above the pipe and for every pipe (including the box culverts) upstream of the circular pipe. The issue seems to be limited to the shape of my pipes. Does anyone have experience with this?
