How I can use the custom structure from infra. parts editor in civil ?.
I publish this using tool in part editor, but civil don't recognize this parts ....
Meybe it's impossible to import this tools to civil ?.
Hi, you might want to refer the following record from the Autodesk University for further detail.
Build Custom Parts for Use in AutoCAD Civil 3D and InfraWorks
Thx.
I just want know how import to civil , add for families and see that it's works in civil ... of the end this movie he sad that it's complicated to import to Civil.
Thx.
After you have finished an assembly in the Parts Editor, you can save your final catalogs in the My Parts library, and publish your final catalogs to Autodesk Civil 3D. ( refer to the below link for publishing)
To publish a parts catalog to Autodesk InfraWorks or AutoCAD Civil 3D
Within Civil 3D, you can then set the new catalog for use in your drawing.
Yeap, and for this time does works.
Trobule coms next- try use any assembly or structure in civil ...
Then show me how u import any surface structure to civil and add for family in civil and this works.
____
Parts editor export just .jpg and .xml file - civil need .bmp .dwg. xml and i think that the main .apc file shpuld be modifided - then civil can recognize this file form parts editor.
____
