Civil 3D surfaces do not support vertical faces.
The steps in stripes.dwg were vertical. I offset the bottom of each vertical face 0.01 toward the center of the trench so there was no vertical face or overhang. I saved the drawing as stripes offset.dwg.
I suspect that stripes and stripes offset are corrupt. Selection all ([CTRL] [A]) shows 389 lines, 2 Xrefs 10 3D polylines and 1 polyline. A window selection shows only 132 lines. ![image.png image.png](https://forums.autodesk.com/t5/image/serverpage/image-id/779107iA83EACB2A7A2AADD/image-size/large?v=v2&px=999)
I selected 1 lines, [Right click] ... Select Similar and Wblock the lines to stripes offset wblock.dwg.
Working with this clean drawing I selected all 132 lines and created feature lines on Site FG. There was a warning and only 131 feature lines were created. (I have no idea what the phantom parcel is.)
![image.png image.png](https://forums.autodesk.com/t5/image/serverpage/image-id/779113i599C502B4BF93121/image-size/large?v=v2&px=999)
I selected all of the feature lines and added as breaklines to surface FG. I ignored the minor error at each end.
![image.png image.png](https://forums.autodesk.com/t5/image/serverpage/image-id/779112i85F766717FAFA535/image-size/large?v=v2&px=999)
I temporarily turned off the display of triangles for FG. Then added lines across the top of the trench, shown in red. ![image.png image.png](https://forums.autodesk.com/t5/image/serverpage/image-id/779119iFE9DC68CA5A58BD3/image-size/large?v=v2&px=999)
I converted these lines to feature lines on Site EG. and added the resulting feature lines to a new Surface EG.
![image.png image.png](https://forums.autodesk.com/t5/image/serverpage/image-id/779124i80D2AEAED95C9E96/image-size/large?v=v2&px=999)
Compute the volume by creating a TIN Volume Surface based on FG and EG.
![2020-06-03 00_35_07-Greenshot image editor.png 2020-06-03 00_35_07-Greenshot image editor.png](https://forums.autodesk.com/t5/image/serverpage/image-id/779126iB0E2C9A5C816D134/image-size/large?v=v2&px=999)
Drawings are attached (2020).
Good Luck.
Christopher Stevens
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
