how to transform topographic survey done by old benchmark to new bench mark in civil 3d ?
Oliver_C3D
Message 1 of 10
Oliver_C3D
Hi
I have Topographic Survey Data done by the old BM But I want to transfer them to the new BM (Correct data) !?
Please help me
Replies (9)
Message 2 of 10
AllenJessup
There is a Raise/Lower Surface command.
I've never used it. So I don't know if it remains dynamic to the objects used to build the Surface. From reading the Help on it. It seems that it should since the amount is stored in the Surface Definition.
Otherwise. If the Surface is created from Points and Breaklines you would have to raise/lower the Points and Breaklines manually. If it's created from a point file. You could bring the file into Excel and calculate new elevations to create a new point file.
Be careful if you bring in new points. Weather they are adjusted or not will probably depend on where definition the raise/lower value occurs.
Allen Jessup
CAD Manager - Designer
Message 3 of 10
Oliver_C3D
@AllenJessup
No ! I do not mean this ! I think the transfer should be done using the Survey tab!
Message 4 of 10
AllenJessup
This has some information:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Cannot-edit-point-...
Allen Jessup
Message 5 of 10
Oliver_C3D
No Dear
thanks
Message 6 of 10
AllenJessup
Well. That's as far as I can go with it.
Allen Jessup
Message 7 of 10
Pointdump
Hi Oliver,
More details please.
Let's see what you've got. Drawings, data?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 8 of 10
Oliver_C3D
Hi @Pointdump
I hope you are fine
A large number of points have been survey using benchmark BM1-OLD.
Considering that benchmark BM1-OLD was not accurate,
now I have to fix all points with benchmark  BM2-NEW  (exact coordinates) in Civil 3D
Message 9 of 10
jroot
Unlock all your Survey Points so they can be changed.
Create a Point Group of all the points you want to change (or select all the points in one of the many ways to do that).
MOVE command, D for Displacement Then enter 0,0,0.066
Re-lock your points.
Your Surface will update, might want to check your surface labels.
Message 10 of 10
AllenJessup
It looks like there would be an X,Y shift also. X of 0.028 and Y of 0.069.
Allen Jessup
