How to stop existing ground contours regenerating
Neilw_05
Mentor Mentor
Message 1 of 27
Neilw_05
I am frustrated with the constant delays while C3D processes existing ground contours while working in a drawing. I have tried turning on LevelOfDetail which helps a lot but it often causes the drawing to hang. The surface is DREF'd into all of our drawings. Since the contours are not changing, I don't need them to regenerate. Is there a way to stop this?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Replies (26)
Message 2 of 27
jroot
Setting the Contour Smoothing to False in the style makes it go faster... but does not stop it from regen'ing.
What if the surface is locked, does it still regen?
Message 3 of 27
rl_jackson
Have you tried turning the contours off (not displayed)?
Rick Jackson
Survey CAD Technician VI
Message 4 of 27
Neilw_05
If we turn off the contours it is easily overlooked at plot time and we end up having to re-plot. That has happened already. I'll try locking to see if it helps. Can't do any testing right now.
WIN 10 64 PRO
Message 5 of 27
Joe-Bouza
Convert DREF type and crop ont the part you need  😮
Joe Bouza
Message 6 of 27
Neilw_05
LOL, this is the project that led me to the Dref variable. Unfortunately this project is a 2500 foot corridor so it is not really suitable for cropping.
WIN 10 64 PRO
Message 7 of 27
Neilw_05
By the way, has anyone experienced hangs when using LevelOfDetail? This has happened on several projects now. I know it is the variable causing it because it stops when I turn it off.
WIN 10 64 PRO
Message 8 of 27
rl_jackson
LOD has been disturbing since the very beginning. 😉
Rick Jackson
Message 9 of 27
tcorey
Try using a Surface Snapshot.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 10 of 27
Joe-Bouza
Of course.👍
Joe Bouza
Message 11 of 27
rl_jackson
@tcorey I was going to suggest that but the help says with large surfaces not to do that. I've had extremely large files doing drone work and mms sucks the life out of C3D
Rick Jackson
Message 12 of 27
Joe-Bouza
I concur. if crop and convert drefstyle is not aceptable
Joe Bouza
Message 13 of 27
Neilw_05
Locking the surface and creating a snapshot does not help.
WIN 10 64 PRO
Message 14 of 27
hamedEWD2S
We are having the same issue with large surface of a 3,000 Acres land and MMS files!
It really slows us down. If anyone can find a way to stop CAD from "Regenerating Contours" of the EG ground, that will save our lives.
Message 15 of 27
neilyj666
Have you tried simplifying the surface with edge contraction and 70-80% point removal? It can take a bit of time but produces great results but be aware the Apply runs the smoothing one and Finish runs it again (just hitting Finish will run it one)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 16 of 27
Neilw_05
That is a good suggestion. Still, why is the software constantly re-processing the contours? The surface hasn't changed. It is maddening.
WIN 10 64 PRO
Message 17 of 27
neilyj666
Yes the constant updating is annoying but I suppose it has to be done due to the dynamic nature of the objects (my personal annoyance is that a simple Zoom or Pan triggers a change in the drawing and it has to be saved before certain operations are possible - surface smoothing being one).
I believe that efficiencies are the main development focus at the moment and this rebuilding would seem a good candidate.
Message 18 of 27
Neilw_05
It is more than annoying. It is a budget breaker. Some of these simple projects are taking far too long because of the performance issues with this software. Let's hope they are looking at this.
WIN 10 64 PRO
Message 19 of 27
Joe-Bouza
Does the snap shot @tcorey  mentioned help? .. Since the original posting I have explored the use
I have used snapshots to some success. the crop surface tool is very useful in reducing load
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Civi...
https://civilimmersion.typepad.com/civil_immersion/2016/03/tool-for-tuesday-cropped-surfaces.html
Joe Bouza
Message 20 of 27
Neilw_05
Snapshots is a no (see #13 above). I have used cropped surfaces on some larger sites. This is a problem on smaller sites that can't be cropped as well.
WIN 10 64 PRO
