how to reverse alignment
I hope the software design engineer could make common use function easy to find
J.FOCHT
Hello @Anonymous!
This article should help you out on reversing an alignment.
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Civil3D-UserGuide/files/GUID-DE880694-1DBD-416D-AAF3-D73DAF80EAEC-htm.html
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Jeew-m
Dear Friend,
click the alignment.
On the ribbon use drop down at modify. You will find it.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
