Sometimes when I open a drawing it asks for shape files that I don't have. Is there a way to remove them from the drawing so this message do not show every time I open the drawing.
Sneja
@BushW has edited your subject line for clarity: Shape files
Solved by lim.wendy. Go to Solution.
Hi @Anonymous
You can assign a font to the FONTALT variable; this will replace any SHX files AutoCAD cannot find. You can look in the STYLE dialog to see what SHX files AutoCAD cannot find, and reassign them there if you wish.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
I am having trouble removing a shape file that is an xref that is no longer even in dwg. I have tried all of these things and even tried super purge which I can not get to run on my pc.
here is what I need removed
APPLINETYPE [SANITARY_1-50_0-06] uses SHAPE # [14] in the file [scadline.shx]
The following SHAPE FILE is loaded: [scadline.shx]
The following SHAPE FILE is loaded: [NORMAN FOUNDERS SITE SKETCH 021819.shx]
anyone out there able to help me?
This link was the solution for me after trying all the above.
