How to pull elevations from a surface profile?
lenfingerSHDVA
lenfingerSHDVA
I'm currently working on a Dam Breach Analysis and I need to pull elevations along various cross-sections of the stream. I have about 20 cross sections, anywhere from 500-1500 feet long, that cross the stream. What I am trying to get is the station along each cross-section and the corresponding elevation. This typically ends up just being the distance between contour lines, since those are the easiest elevations to determine. I can do this manually by simply measuring the distance to each contour and having a 2-column spreadsheet with X and Y coordinates. However, I am sure there is a simpler way.
What I've done so far is this: make each cross-section line an alignment, and then create a profile view for each of these alignments. I have a visual depiction of what each cross-section looks like, but I really just need the data in a spreadsheet. Does anyone have any ideas for how to achieve this in a more efficient way?
P.S. This is my first post on here, so I apologize if I didn't include enough/necessary information. Please comment and let me know if you need more info.
nkiakas
Hi @lenfingerSHDVA
if you want to make it proper you should start by creating alignment(s)/profile(s)/surface(s).
Could you please share your file to understand more?
ChicagoLooper
Hello @lenfingerSHDVA
Toolspace=> Toolbox tab=>Expand Profiles=>Incremental Stationing Report=>right click execute=>select alignment=>adjust Station Increment if needed=>Create Report
You may also watch this >>VIDEO<<.
Chicagolooper
lenfingerSHDVA
I'm getting a message that says "No FG profiles in *filename.dwg*". Any idea what that means? I have a profile created but I'm not sure what FG means in this context.
ChicagoLooper
Refer to this previous >>post<<.
Chicagolooper
lim.wendy
Hi Logan,
Welcome to the Civil 3D forum. Thanks for reaching out to the forum. It looks like @ChicagoLooper provided you with the steps to get the report, so for now, I am going to mark this thread as "Solved." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
