How to offset contour line to a specific elevation?
martin.hong
martin.hong
Hey all, new to Civil 3-D so still learning, but basically I have a wetland design and I'm trying to draw in a contour line that would be 0.95 meters below the existing surface. Since the EG changes along the wetland, I don't know a specific elevation, only that it's 0.95m lower. What's the best way to extract this line in Civil-3D? I attached a snippet for reference.
Thanks!
Accepted solutions (3)
Udo_Huebner
Create an Offset Surface to the EG
using
1. CreateSurface EG-095 (Command "CreateSurface ")
2. PasteSurface EG (Command "EditSurfacePaste")
3. Lower Surface EG-095 for -0.95 (Command "RaiseLowerSurface")
4. finally create an intersection between EG-095 and the proposed Ground (Wetland Surface) using
(Command "MinimumDistBetweenSurfaces")
Gruß Udo Hübner (CAD-Huebner)
MMcCall402
Another option:
Create a volume tin surface using the EG surface and your design surface.  On that volume surface define a User contour at elevation -0.95.  You can extract that contour if needed.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
jroot
Create a polyline at your edge of wetlands. Turn the polyline into a Featureline and get it's elevations from the EG surface. Lower the elev of the Featureline 0.95.
