@brian.strandberg wrote:
I took a look at the project explorer object sets tables, and don't see anything to fit this need aside from using the pipe name. No general sequence (1,2,3,etc).
You mean Autodesk said an Idea was implemented that wasn't? 🤥
But to be fair, it's the ability to edit the table as an AutoCAD table that would allow for the sequencing. Whether that has to be done every time the table needs updating is a question I cannot answer.
But the idea of using pipe names is really the only way to do this, but if the pipe name is already being used and/or cannot be used for this purpose then the OP has no easy way. Maybe use Project Explorer to export the table to an Excel file, add the sequencing there, and make an AutoCAD table that references that Excel file?
C3D 2024-2026
Windows 11
32GB RAM
