How to make the drawing loading faster?
Wilson.WanH8Q64
Message 1 of 8
Wilson.WanH8Q64
There are 2 surfaces in the drawing. I only need the contour line and profile. Is there any way to make the drawing loading speed faster? When I zoom in zoom out, it took forever to load. Thanks.
Replies (7)
Message 2 of 8
m_kingdon
Do you have the command LEVELOFDETAIL on?
You could also try masking / clipping out sections of the surface you don't need if it is a big surface.  And layer management, freeze layers you don't need.
Mike Kingdon
Civil 3D Zealot
Message 3 of 8
Wilson.WanH8Q64
It works. Thank you so much.
Message 4 of 8
Wilson.WanH8Q64
Oh, but it loads every time when I switch between model and paper space. Is it normal?
Message 5 of 8
Wilson.WanH8Q64
Is it possible to reduce the mesh size/ sample point? The grid is 1m. But I don't need these resolution. Check the properties of the surface and I can find any setting to alter it.
Message 6 of 8
m_kingdon
What type of surface are you using? If you are working with TIN surfaces you can use the SIMPLIFY SURFACE feature to reduce the number of points. I do this often with drone surfaces that are delivered to us as monstrously large tin surfaces.
Mike Kingdon
Civil 3D Zealot
Message 7 of 8
MMcCall402
My drawings load faster when I drink less coffee.  😁
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 8 of 8
Wilson.WanH8Q64
I use DEM surface. Would if be different if I convert to other one ?
