Hi, i have some issued to make a shape code between Loop Geometry and other link, it like this. if you know please help.
Hi @teerawat.pSCHYQ, I have an idea, but I would need your PKT to test it. Could you please share it?
Regards!
Hi @teerawat.pSCHYQ, thanks for posting the subassembly, and sorry for not responding earlier, but I already checked the possibility of creating the shape with the looped geometry, and I found this is not possible. It turns out it is not possible to say in advance which links will enclose the shape. Therefore, the shape cannot be inserted.
A solution for this problem is to program each step of your loop manually, but you should program as many steps as you believe you'll have in your model, which is a lot. Once this is done, we can certainly know which link elements the shape will be comprised of. (I have personally done this with Slope Daylight Benches for roads, but the dimensions are greater, and I have modeled six benches maximum)
Let me ask you, what are you trying to model? Can you explain better your idea with this subassembly to see if I can provide another idea?
Best regards!
Hi @ecfernandez , your idea like what I thinking that I need to do manually for each steps, the model that I would like to make that is RCC Dam (Roller Compacted concrete Dam) like this , that you see is many step
and I would like to have hatching in each shape code like this when i do cross section at each station of dam alignment (axis)
