Civil 3D Forum
How to join ploylines
6 REPLIES 6
fishautodesk124
271 Views, 6 Replies
I currently have a long polyline made of many curves and lines which is about a mile long. I know how to hook this up by clicking on every segment and place the join command but this is takes a long time. Is there a easier way to do this?
Windows 10 Professional Pro
Intel(R) Core(TM) i7-6700 CPU @ 3.4 3.41 GHZ
16 GB
64-bit Operating System x64-based processor
AutoCAD Civil 3d 2016 sp 4
6 REPLIES 6
in reply to: fishautodesk124
Hi
I suggest looking up the help menu in AutoCAD for 'select objects' or doing an internet search. Here is the first hit I found which should cover some things that could help you.
http://www.mycadsite.com/tutorials/level_1/selection-sets-in-AutoCAD.htm
Also I find using the SELECTSIMILAR and the ISOLATEOBJECTS command useful to select only what want.
Cheers
you can use command _PEDIT with the first option "Multiple" ==> than you can select all segments with window or crossing-window selection and use option _JOIN.
Another option might be command _MAPCLEAN, more complex but also more powerful.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
neilyj666
in reply to: Alfred.NESWADBA
I use the Crossing window and Join method.....but the end level of preceding line must be the same as the start level of the next line or the command will fail.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
antoniovinci
in reply to: neilyj666
I prefer MAPCLEAN with "Dissolve pseudo-nodes" option, but if I'm in a hurry, I use PEDIT=>ALL=>JOIN, fast and safe.
neilyj666
in reply to: antoniovinci
.....but need to be aware of any "cross linking" polylines that may cause the JOIN to form the new joined polys in a weird way...;)
antoniovinci
Good point, N: when you have crossing lines, it's mandatory to run Mapclean indeed.
Rail Community
