How to intersect dam slope with target surface?
Dear Autodesk people,
I would like to create assembly from a earthfil dam cross-section and run a corridor to create the dam itself. How can i make assembly so that it will daylight to a specified target surface. I could not find a way to do it. There is an example in the following link:
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Civi...
When i follow each step, I am unable to daylight the dam cross-section to the specified target surface.
Thank you
igi_pop
Thank you
Hello!
I've just made up a few objects and it works just fine for me.
Do you have a screenshot of a cross-section on what you get?
Things to keep in mind:
- you need to have a design profile AND SELECT it when creating the corridor. By default, when using alignment and profile, i think it always selects the first created profile which is more than likely your EG profile. That would draw nawt or jibberish
- looking at the dam subassy (that's the nov 2017 beta, right?) your design profile needs to have space. Core crest thickness + a little, otherwise it jibberish again.
- if your profile for the corridor doesn't run the entire length of the alignment, and you sample outside start<->end of profile stations - you'll get nawt.
These are the first things of the top of my head, if you check those as "DONE" let us know, give us a screenshot or two and we'll see what's what 🙂
Cheers,
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Dear Iggy,
thanks for your reply and effort. Can you attach your file for me to have a look at it, or can you explain the steps that you have followed?
igi_pop
@Anonymous wrote:
Dear Iggy,
well, i would if i followed some written steps 🙂
- create (or insert from dref) a surface
- create (or insert from dred) an alignment
- create a surface profile and profile view
- select the profile view and then "profile creation tools". Just make ONE TANGENT profile named TEST for testing purposes that is ABOVE your existing ground
- create assembly with the DAM subassy
- create a corridor with "alignment and profile" , select apropriate ali, profile, assembly, and check the box where is says "set parameters"
- in the next dialog, set your target (existing ground) and interval (i've set it all to 1m)
- PRESTO!
There it is 🙂
(wait..making file for attachment)
There you go!
Cheers,
Iggy
