How to handle Crossing target surface
juan_m_urena
juan_m_urena
I am creating a ramp down an embankment.   I am using a 12ft road with a 3H:1V fill slope targeting an existing surface.  The surface targets cross each other at the turn, as shown.   Any suggestions on how I can deal with this issue?  I cannot change the horizontal curve.
@Pointdump
M_Obradovic
Hi @juan_m_urena ,
If I see good you use corridor and you have overlap daylights due to less curve in your alignment. You can try to solve issue in two ways.
In firsts way try to use corridor bowties as you can see on video bellow https://youtu.be/pAlq8QYYtdY?si=OiQuFr_JjMkdkSDg
other way you can use is grading tool.
hope this help you
cheers Milos
juan_m_urena
@M_Obradovic   thank you for the help.
Joe-Bouza
this How I would do it
split the regions and in between use road only, add you own dayligh FL (green) and the surface should fill in on its own
Joe Bouza
