How to Get Data Points from Existing Contour lines
s20215430
Message 1 of 11
s20215430
hey i have this project im working on, where i need to design a road. I was given a file that has a contour map. i am not sure how to get started because i would like to get the data points derived from the contour map. Can anyone help me with this?
Replies (10)
Message 2 of 11
Pointdump
Hi Danai,
Welcome to the Autodesk Forums.
Your drawing already has a surface, so the next step will be to create an alignment.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 11
s20215430
Is it possible to get all of the points on the contour in a text file, showing x, y, and z values.
Message 4 of 11
Pointdump
Danai,
You want to extract the polyline vertices? I don't think data extraction can do that. I might be wrong.
You can extract the 441,404 surface points.
More details please on what you'd like to do.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
s20215430
I would like all of the points along the contours extracted and in a .csv file so i can upload the points into other projects as new points.
Message 6 of 11
Pointdump
Here you go. 482,739 points! I wasn't able to extract the vertices in AutoCAD, so I used QGIS. Very convoluted. Maybe someone will chime in with a better way.
Extracting the 441,404 surface points would be far easier.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 11
s20215430
How would one extract the surface points efficiently?
Message 8 of 11
Pointdump
Danai,
In your drawing, Turn on "C-TOPO" layer, turn off "CONTPRINCP" and "CONTREGULR" layers.
In your Surface Style, turn on "Points". Select your Surface. Extract Points.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 11
Pointdump
Danai,
I forgot to add the last step, DATAEXTRACTION.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 11
s20215430
Thank you so much, you have been such a big help!!! I hope all your future endeavors go as smoothly as our interactions. Good luck!
Message 11 of 11
Jeew-m
If your first task is to create a surface, You can easily do it through these contours.
No need to extract points data at all.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
