Hello, I need to get 2 pipes connected to the catch basins as shown on the photo below. I need at least 1 pipe connected to structure so it shows on profile correctly. How do I get at least 1 pipe connected to the catch basins so that the pipe is shown like on the photo, where it does not connect to the center of the structure, rather it is offset and 2' between the other pipe.
Solved by MMcCall402. Go to Solution.
When you draw the pipe, a little "connect" icon will pop up when you hover over the structure to join to.
The hover icon connects pipes to center of structure, but I need the 2 pipes to connect like what is in the photo where they arent in the center. I think I am going to have to place 4 null structures on top of the 2 catch basins and do it this way.
You can move the ends f the pipe(s) within the structure once they're connected. Be sure to keep the end of the pipe within the limits of the structure or it will become disconnected. If you move the structure after relocating the ends they will snap back to the middle of the structure.
