Hi All,
I have a question that is related to automation of a simple task. My background is hydraulic modelling of water networks. A water network for a city can be an elaborate system. Civil3d has well devised import mechanism to import model data in shapefile format.
For interference analysis, profile plotting and other allied tasks, the network pipes must have associated surface and alignments. Civil3d has multiple alignment generation options. However, it seems, all require significant man-hours (when it is a city scale branched network). I can dissolve the pipe network into polylines that can be used as objects for alignment generation. For each object, I left a unique integer ID in DF field (of the shapefile).Mapimport Shape with unique ID for each polyline
Create alignment from objects
Alignment generation definition to be replicated for each polyline object.
My question is, is there any application or script that can take the polylines and generate alignment for each polyline without requiring any user intervention? Attaching a sample file that contains the polyline objects that need to be converted into alignments. For the seven polyline objects in the file, I want to generate seven corresponding alignments; preferably named 'Alignment - DF'. The process should be automated.
Much appreciate a quick response. Thanks in advance.
