How to flip 3D polyline arc?
jlmJRVB8
jlmJRVB8
Community Visitor
Community Visitor
I am trying to flip or reserve an arc direction in Civil 3D. The points were shot using a BC and EC and they have imported the 3D polyline concave to the East and it should be concave to the West. Is there a way to reserve this arc without exploding the 3D polyline and manually drawing the arc?
Thank you so much in advance!
Neil.Aryan
@jlmJRVB8
How about double click the 3dpoly line and choose the option reverse on command prompt?
If its an ARC make sure convert the same to 3dpoly/2d poly and then double click it and select reverse option it will change the direction.
Hope this will be helpfull.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
hippe013
Are you sure that you are talking about a 3d Polyline? Or are you referring to a featureline? 3D Polylines cannot contain arcs.
lynn_zhang
Hi @jlmJRVB8
Did the response above help answer your question? Let us know if you still need help.
Lynn Zhang
