Hello;
I am installing AutoCAD Civil 3d but when I try to run the software, this error display"the application was unable to start correctly (0xc000007b). Click OK to close the application"; I wonder if you can help me please.
Thank you.
Solved by AllenJessup. Go to Solution.
Have a look at this autodesk article:
Most likely you have to Uninstall and reinstall all the Microsoft Visual C++ Runtime Libraries to fix this.
That's a Windows error message. If you look HERE you can see some suggestions on how to fix it.
If i made a guess. I'd say repairing or reinstalling Civil 3D would be the most likely to succede.
Allen Jessup
CAD Manager - Designer
