The scenario: I was given a datum tin surface (no feature lines or CRDR) and I need to trim areas up in order to merge it into another surface. The issue is at the curb & gutter locations where the datum surface goes from bottom of subgrade to top of curb in the shortest of distances, so unless you really zoom in, the two points are effectively on top of one another. Picture a section view, the surface is shaped like an L. I need to delete that top of curb point so I only have bottom points. The two points are so close together it would take me forever to manually zoom into each triangle, pick and delete the top point. The curb and gutter offsets vary as well, so I can't create an offset polygon and use as a surface boundary. Any ideas?
RJ
C3D 2016
