Can't select Surface point in 3D view
AllenJessup
Mentor Mentor
AllenJessup
If I try to select a Surface point to delete while not in a Plan view. I get an error when I select the surface. The Style has Points set to display in Plan and Model. Is this normal behavior?
IDSP 2017 SP 1.1
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro K4000
Samsung SSD 512GB
HGST (WD) 512GB drive
Allen Jessup
CAD Manager - Designer
sboon
Apparently it is.  I found that when I select a surface from a 3d viewpoint the contextual ribbon is different than the one in plan view, and it doesn't include surface editing commands.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Topmig
Hi Allen,
Just tried in a surface that i have here, and when i rotate the view, the points disapear..
Just went to the surface style, and turned the "points" on again at the display tab.
Can you please attach the file to try if it work's here?
Best regards.
AllenJessup
@Topmig I'm glad you posted. The drawing I'm working on was too complicated to post. So I created a simple one for posting. I tested my problem in the new drawing and I could select the Surface Points to delete. I pasted the Surface I was working on into a new drawing. I can delete the points now.
Allen Jessup
AllenJessup
@sboon I had the problem because of some corruption or glitch in the drawing. If I create a new drawing and Surface or paste the Surface into a new drawing from template. I can select and delete Surface points in a 3D view.
Allen Jessup
