how to create the transition element for a 3 lane road
Message 1 of 9
Hi community,
we are currently designing a german 3 lane highway and we have a problem with the transition element between the left-sided 2 lane into the right-sided 2 lane.
We are not sure, if we just dont´t find the right tool for it or if there isn´t a tool to design it at all.
Hopefully you guys can help us with our problem.
Best regards
Nils
Replies (8)
Message 2 of 9
jae.kwon
Tell us more...
Message 3 of 9
So, the problem is, that we don´t find the tool to create a section for the passing lane between the right-sided double lane and the left-sided double lane.
We are able to to create the left-sided and right-sided double lane of the street, both of them at maximun length of 2000m, but we don´t find the object to create the pasing lane section between it.
Message 4 of 9
ilia.borisov
Maybe I dont fully understand your issue but did you try MarkPoint subassembly?
Message 5 of 9
And were did I find this Markpoint subassembly?
Message 6 of 9
ilia.borisov
Press CTRL+3 and then search for Generic tab.
Message 7 of 9
Here are some photos of what we need in our project.
Message 8 of 9
jae.kwon
If I'm understanding what you need correctly, I think you just create an assembly for that region that has 2 lanes on the left and 2 lanes on the right and use offset targeting lines to make the outer lane narrower until it becomes pretty much non existent (1mm wide?)
Message 9 of 9
lynn_zhang
Hello @Anonymous , welcome to Autodesk Community!
Just checking to see if your problem has been solved. Have you tried the above suggestion and did it work? Let us know if you still need help.
Lynn Zhang
