How to create profile from file without alignment in civil 3d!?
giscivil92
Message 1 of 20
giscivil92
Hi
I am looking for a solution to create a profile from a file without alignment it means the software asks only text file .
Replies (19)
Message 2 of 20
nkiakas
Hi @giscivil92
I think profile is not something independent.
The minimum information of chainage+elevations are connected (linked) with a linear 2D object (line, polyline, curve, pipe or alignment.
Due to this i don't think is able to make profile without alignment in C3D.
Message 3 of 20
giscivil92
@nkiakas
Yes sure, but according to kind of my job,I want to create a profile from a file without alignment or polyline and etc.
Message 4 of 20
g_p2830446
Community Visitor
Community Visitor
Hello, In Civil 3D, to create a profile from a file without alignment, you cannot directly create a meaningful profile because profiles in Civil 3D are typically associated with alignments to provide the horizontal context for the profile's vertical information. However, if you just want to import vertical data (like elevations) from a file, you could manually create a "dummy" alignment and then import your elevation data to create the profile. But remember, without a proper alignment, the profile won't accurately represent the intended path of the project. Normally, you would import the data (often CSV or TXT format) containing the station and elevation points, then use this data to create a profile, but it needs to be associated with an alignment to make sense spatially. Always ensure your data is correctly formatted and corresponds to the intended horizontal alignment for accurate representation.
Message 5 of 20
Joe-Bouza
Can you explain that a little further? The file will have a form is station elevation.
what station are we talking about?
Joe Bouza
Message 6 of 20
giscivil92
@Joe-Bouza Hello, thanks for your attention, I have some data such as km, elevation
I want to show them as profiles in civil 3d without alignment from a file, only this.
Message 7 of 20
Pointdump
Hi Giorgi,
How about importing Station,Elevation into your drawing as X,Y?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 8 of 20
giscivil92
Yes, I can, but I would import as station and elevation from the file directly.
Message 9 of 20
Pointdump
Giorgi,
OK, so why isn't that working for you? Please show sample Station,Elevation snippage and what you want it to look like.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 20
giscivil92
@Pointdump
A text file like this.
Message 11 of 20
Pointdump
Giorgi,
OK, and what do you want it to look like in your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 20
giscivil92
create a profile from this file directly without alignment.
Message 13 of 20
rl_jackson
With the limited amount of data available, the alignment would be a straight line. Therefore, it would be really easy to create an alignment with points at each station based on the elevation, copy same at a equal offset left and right of the alignment to create a surface to sample and create the profile from that.
I don't know of any other solution with that limited dataset.
Rick Jackson
Survey CAD Technician VI
Message 14 of 20
giscivil92
Hello dear @rl_jackson
Thanks for your suggestion,
I am looking for other solution.
Message 15 of 20
Pointdump
Giorgi,
What do you want your Profile to look like?
Importing your Station,Elevation file as X,Y creates a Profile.
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 20
ChicagoLooper
@giscivil92
<<... create a profile from a file without alignment...>>
Yes, you can use a file, buuut.........
From Civil3D 2024 ribbon.From Civil3D 2024 ribbon.
........... you can't create a profile from just a text file, you'll need an alignment too.
If you want to create a profile from a text file, you'll STILL need an alignment because those Station No's are critical. In terms of a profile view you'll notice the vertical axis is your elevation while your horizontal axis is your X,Y position.  IOW, the horizontal axis will index a point on your alignment. This means the horizontal axis is a continuum of POINTS along your cut line. And that cut line represents by your alignment. When elevation and station position are put together you get the makings of the profile.
Think of your birthday cake. When you slice it up, you hold your knife parallel to left edge then parallel to the top edge to cut the traditional square birthday slice. If you want to serve funky shaped slices, you cut at an angle instead of parallel. And if you feel creative you can even use a steak knife and cut curved pieces.
Whatever knife and angle you use, your knife needs to have a cut path, an alignment, to cut slices. Without a cut path you'd have no slices. And without slices your guests will be eating uncut cake with their hands caveman style. You better have lots of napkins.
Here's a 6-minute video by Jerry Bartels that explains how to do it. (He explains the 'rules' when using this method.) His txt file he has both station number and elevation (you may add curve data too). And in addition to his txt file, he has the mandatory alignment.
To watch the video click >>HERE<<.
https://www.youtube.com/watch?v=BrjgwgiA93Uhttps://www.youtube.com/watch?v=BrjgwgiA93U
Chicagolooper
Message 17 of 20
Joe-Bouza
Ok. You know the km range.
draw an arbitrary  straight line alignment x km long. Read the file and plot the profile
Joe Bouza
Message 18 of 20
ChicagoLooper
@Pointdump
Unfortunately that txt file isn't x,y. It's actually Station# and Elevation. When there are station numbers, it means somewhere, some place, someone created an ALIGNMENT.
You can see how it's done by watching the 6-minute video by J. Bartels. See the clickable link in post #16.
Chicagolooper
Message 19 of 20
neilyj666
Although the suggestion put forward by @Pointdump could create a pseudo profile if imported correctly i.e. the station would be x coordinate and the elevation would be y coordinate, it wouldn't be dynamic or relate to any real world objects
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 20 of 20
ChicagoLooper
@neilyj666
I wasn't implying it wouldn't work, of course it would work.
....The Station number is on the left and the elevation is on the right. You can read about the format for the txt file >>HERE<<.
Chicagolooper
