how to create a profile from text file
yemigere
Message 1 of 12
yemigere
hello there! when i am trying to create a profile from a text file it will appear as the picture i uploaded below in the panorama view...what do you think is the mistake i did and what should i do?
thanks in advance!
Replies (11)
Message 2 of 12
m.mitic
Message 3 of 12
Jeew-m
Check your first row and last row.
It should contain only 2 readings (station and elevation) - Refer to the attached link by @m.mitic.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 4 of 12
yemigere
that really helped me to solve the problem but again I am facing a problem ….I have attached what I found in the panorama view .....your suggestions will help me a lot.
Message 5 of 12
m.mitic
pay attention to this, it can be a common problem when switching from excel to txt
in row data are divided by "space" not "tab"
Message 6 of 12
m.mitic
can you attach your txt file?
Message 7 of 12
yemigere
yes of course... here is it..
Message 8 of 12
m.mitic
this is what i found
62583.274 2541.346 80
62642.93 2534.188   the order of stationations is wrong
62640 2534.188       the order of stationations is wrong
62868.339 2506.791 100
62983.932 2499.884 90
63141.182 2481.471 60
63359.646 2460.667 140
63679.905 2465.42 190
63917.005 2440.1983        the order of stationations is wrong
63715.28 2460.509           the order of stationations is wrong
63720 2460.509
63684.621 2465.42           the order of stationations is wrong
63917.005 2440.7 160
64117.655 2434.33 120
64361.129 2435.668
you need to check the whole file
Message 9 of 12
yemigere
Oh thank you so much i will check it!
Message 10 of 12
yemigere
depending on your suggestions I have checked all my data, …first I re-ordered it to ascending order then deleted the repeated stations because of station equation and also deleted the first and last rows curve data...but still the panorama window shows message 'input file has invalid geometry' and I don't really get what the problem with my data is .....so can we say that the vertical alignment data is incorrect? if so, how could it be corrected? I have attached my final data  below.
thanks in advance
Message 11 of 12
m.mitic
64638.715
80870.001
in these places there are duplicate stations with different heights which implies a vertical profile layout part,
civil 3d does not allow vertical lines when creating profile layout
Message 12 of 12
ivs_gopal
Observer
Observer
HI
IN YOUR TEXT FILE THERE IS A SMALL GAP BETWEEN CHAINAGE AND ELEVATION, PLEASE CHECK
