How to creat "link to mark point" subassembly by Autodesk Subassembly Composer??
taophatxit
Message 1 of 12
taophatxit
 Hi guys!
I'm trying to create a Median subassembly by Autodesk Subassembly Composer (ASC) like "MedianRaisedConstantSlope" in Tool palettes.
I used "get mark point" - tool box in ASC to creat a link to mark point existing. but when i add it to my project, it's wrong and appear error box " Markpoint does not exist. "
How can i make it?
Accepted solutions (3)
Replies (11)
Message 2 of 12
CivilFlow
Try to put the marked point at the end of your flow chart.  I think because you have it as the very first element in your flow chart, C3D doesn't know what to do.
Also, check out the attached example .pkt for Marked Point provided with SAC help.  This example shows the marked point at the end as well.  I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 3 of 12
taophatxit
Thanks for your help but i don't think you understand me! In your attach file, i see you use "Set mark point" - i think it mean something else with connect to this point and create a line.
In my case, the mark point is already existing and i want another connect to it as median.
Message 4 of 12
Jowennl
Hi @taophatxit,
Use this Get Marked Point in the Advanced Geometry. See attached images and sample PKT.
SAC - Get Mark PointSAC - Get Mark PointIn Assembly - Order is importantIn Assembly - Order is important
Cheers,
Jowenn
Message 5 of 12
Jowennl
Hi @taophatxit,
Also, please try to use ALL CAPS, instead of using m1 try M1 or MP1 or MP2 for both Marked Point Name and Get Marked Point.
Before and after all capsBefore and after all caps
All Caps for the Marked Point NameAll Caps for the Marked Point Name
Cheers,
Jowenn
Message 6 of 12
taophatxit
Thank for your help! now i know it cant use with different assembly. But how the default assembly - "link to mark point" in Generic and "MedianRaisedConstantSlope" in Median can work pefectly in my case?
i try your assembly but it still only work if i put it in 1 side of median.
Both side median i create by offset .
Message 7 of 12
Jowennl
Hi @taophatxit,
Without seeing the drawing it is harder to debug your issues. In my end when I try the sample pkt I send to you and the median pkt you created both works fine without an issue. I believe it is something with the order you create them. Key thing to remember that you need to be consistent with mark point name and use all caps. Are you able to share dwg if you still can't make it to work? I can't find what's wrong as it is working on my end when I test it.
Here's my comments to the image above.
CommentsComments
Cheers,
Jowenn
Message 8 of 12
taophatxit
Here is my file! can you help me correct it? i tried but it still fail!
Thank you a lot for your support!Heart
Message 9 of 12
Jowennl
Hi @taophatxit,
Please use All Capital letter. I keep on telling you to update the name and you are not doing it that is why it is not working. (See images below to show you what I mean by all capital letter)
See animated gif. (I deleted all and just isolate the issue for demo purpose)
Use Capital LetterUse Capital LetterWorkflow 1Workflow 1Workflow 2Workflow 2Workflow 3Workflow 3
Cheers,
Jowenn
Message 10 of 12
taophatxit
Oh my god! A bit mistake make me waste 2 days to think about it! Thank you a lot! You make my day!Smiley LOL
Message 11 of 12
liujingxin123
Two alignment ,one is curve,the othe is line,Now I want to creat “link to mark point”,the marked point on offset assambly ,and then can make link with the subassembly and offset assembly ,How can I make it ? Thank you .
Message 12 of 12
liujingxin123
Two alignment ,one is curve,the othe is line,Now I want to creat “link to mark point”,the marked point on offset assambly ,and then can make link with the subassembly and offset assembly ,How can I make it ? Thank you . or is there the other way to build this corridor ?
